PostgreSQL Backup stuck at 88%
  • January 11, 2022
  • 628 views
once again I have a strange problem. We have set up a PostgreSQL backup and wanted to create an initial full backup. Data was transferred and everything looked good so far. However, at 88% the job stops. Under Log for the Job I only get this information.
23258 5ada 01/11 16:34:15 3840492 IDXCONNECT *****************USING NEW INDEXING LAYER**************
23258 5ada 01/11 16:34:15 3840492 IDXCONNECT Stream Id not set, Generating it
23258 5ada 01/11 16:34:15 3840492 IDXCONNECT Initializing Indexing connection to client [cvmapapp01] from [fxvsdpg2], Setting log mode as offline
23258 5ada 01/11 16:34:15 3840492 CVArchive::ConnectSessionToArchiveManager() - Attaching to CommServer [cvcspapp01] from Platform Type 4
23258 5ada 01/11 16:34:15 3840492 CVArchive::ConnectSessionToArchiveManager() - Attached to CommServe
23258 5ada 01/11 16:34:15 3840492 IDXCONNECT starting afile (2,194,8136411)
23258 5ada 01/11 16:34:15 3840492 CVOnDemandSvcClient::SubmitTask() - On Demand service CVODS_logmanager_cvmapapp01_1 launched at host cvmapapp01*cvmapapp01*8400*8402. Unique ID is 0120018F-4E08-4B7C-9FEA-F5A8192A68C9
23258 5ada 01/11 16:34:15 3840492 Got ODS Guid [0120018F-4E08-4B7C-9FEA-F5A8192A68C9] from server [LogManager] Host [cvmapapp01*cvmapapp01*8400*8402]
23258 5ada 01/11 16:34:15 3840492 IDXCONNECT entire afile (2,194,8136411) is valid
23258 5ada 01/11 16:34:15 3840492 CVOnDemandSvcClient::Attach() - Successfully attached to on Demand service CVODS_logmanager_cvmapapp01_1 launched at host cvmapapp01*cvmapapp01*8400*8402. Unique ID is 0120018F-4E08-4B7C-9FEA-F5A8192A68C9
23258 5ada 01/11 16:34:15 3840492 IdxUtil::addBrowseAblePathIndV2() - calling idx.backupDone(1)
23258 5ada 01/11 16:34:15 3840492 PGPERFMONITOR::PGTimer::logSummary(433) - Function/query   #of calls  Elapsed Time(sec)
23258 5ada 01/11 16:34:15 3840492 PGPERFMONITOR::PGTimer::logSummary(436) - sendMetadataIndex   1  0.203651
23258 5ada 01/11 16:34:15 3840492 PostGresClBackupBase::exitHere() - DBG: sendDirChange with finalize called
23258 5ada 01/11 16:34:15 3840492 NoPrefix Heartbeat timeout is set to 1800
23258 5ada 01/11 16:34:15 3840492 *******************Using new Indexing layer*******************
23258 5ada 01/11 16:34:15 3840492 [::sendDirChange]: creating one line dirchange
23258 5ada 01/11 16:34:15 3840492 [::sendDirChange]: createindex will process dirchange [/opt/commvault/Base/Temp/Idx_23258_1]
Has anyone encountered this problem before and could it be solved ? We have already reinstalled the agent but again without success. Our database admins don't have a solution either.
with kind regards
Thomas
Best answer by Meera
Hello Thomas,
We may see this hang when log archival doesn’t work properly. Can you please verify log archival is fine by running the following queries:
select pg_start_backup(‘Testing’);
select pg_stop_backup();
These should complete fine and you should see the transaction logs archived to WAL directory when second query completes. If second query hangs, archive_command in postgresql.conf need to checked and user, write permissions to it need to be checked.
Meera
Meera
  • 71 replies
  • January 11, 2022
Hello Thomas,
Meera
  • Byte
  • 169 replies
  • January 12, 2022
Hello @Meera ,
thanks to your post we could solve the Problem.
Thank you
with kind regards
Thomas
Cookie policy
Cookie settings
