Raspberry Pi backup agent (64 bit OS)
Marcel
Commvault Certified Expert
  • Commvault Certified Expert
  • 12 replies
Hi all,
Question, just for personal sake..
Is it possible to backup a rasberry pi (64bit OS) using a commvault agent?
I know it is not supported, however I hope someone got it working anyway.
I tried to push it an received an error:
Error Code: [68:175] Description: Failed to install File System Core Package, could not determine processor/OS type of client.
thanks
Marcel Vis
Best answer by Marcel
I just installed the 64bit arm version of the Commvault agent (11.28) locally with sudo ./cvpkgadd, and it simply worked!
Backup is running as we speak 馃榿
Forum|alt.badge.img+23
My understanding is that Raspbian is Debian based, but not the same.  I assume you are trying to push the Linux client out?  I wouldn鈥檛 except it to work since it鈥檚 not on the supported OS list.
Hi @Marcel as @Mike Struening  stated I would not expect this to work but as a workaround could you possibly still capture the system data from by exporting a NFS share to another client, then creating a subclient to backup the shared contents?
Marcel
  • 12 replies
  • August 19, 2022
Hi @Mike Struening  and @Scott Reynolds , yes as stated in my starting post I am looking for a way/hack to install an agent on the RPI.
If there is really no way, I will go ahead and do the NFS sharing.
Rather than a remote install, I鈥檇 try copy the packages locally or mount a share and install direct from the client - its going to be easier to troubleshoot from there.
Are you sure a 64bit OS is installed? By default it deploys 32-bit raspbian using the standard installer (Noobs I think it is).
Jos Meijer
  • 638 replies
  • August 19, 2022
You will probably need to manipulate the detect file, here are the checks located for OS etc..
Marcel
  • 12 replies
  • August 19, 2022
Thanks guys, I will attempt that somewhere next week.
Yes, it is the 64bit (non-default) version
Marcel
  • 12 replies
  • August 19, 2022
Well done, @Marcel !!!!
Feel free to mark your the best reply as the Answer!
Marcel
  • 12 replies
  • August 19, 2022
Thanks to @Damian Andre 鈥檚 simple but effective hint
馃憤
Cookie policy
Cookie settings
