I have a problem with IndexServer object for one storage policy. For some reason backup of Storage_Polixy_IndexServer started failing (its in running state and never completes). No events listed in the job window. Last synthetic backup failed for all clients for that policy and its probably because Index issue (not 100% sure). Is it possible to create a new one.
I know that is created automatically when storage policy is created. Anyone had done that before?
CommVault ver. 11.20.9
Thanks.
Recreate IndexServer object for storage policy.
Best answer by Alireza B
The fact that Synth Fulls are failing shows most likely something is wrong with Index DBs. IndexServer.log can show you more details on the Index Server but I suggest you log a support case so we can review.
