Restore spool file using IBM i File System Agent
  • December 27, 2021
  • 235 views
We are using the IBM i File System Agent to backup our IBM partitions. We want to test restoring a spool file and can’t find CommVault documentation on how to do this.
Is anyone using the  IBM i File System Agent and/or have information on how to restore a spool file?
Thank you,
Jennifer
Best answer by Stuart Painter
Hi @JenniferS
Thanks for the question, we have some documentation for Spooled file data restore:
IBM i Full Data Restore Options
Restore Spooled file data (SPLFDTA)
Select this option to restore the spool files when you restore OUTQ objects.
The software selects this option by default.
IBM Documentation for Spooled files and output queues
Stuart
Hi @JenniferS
Stuart
