Retire VM Group or Subclient
  • September 15, 2023
  • 8 replies
  • 581 views
we have a few VM Groups which I want to disable and exclude from the Schedule. The VM Groups are associated to a Server Plan. If I disable the Backup of the VM Group the Backup Schedule will start the Backup like for the other associated Clients but will fail in the end.
Is there a way to disable the VM Grroup and keep the Backups and also disable the VM Group from being triggered by the Schedule?
The Job is also visible as Failed in the Job List and all the Reports which is a little bit confusing.
Kind Regards
Florian
Best answer by Navneet Singh
@flokaiser
You can go to adminconsole>Manage>Plan and go to associations
@flokaiser
We don’t suggest to change the associations from the Commcell console if the associations are made with plans
You can remove the association from the plan level and monitor the environment.
  • Byte
  • 48 replies
How can I remove the association from the plan? I only can change to a different plan in the VM Group.
Can I still restore after I change the association?
  • 141 replies
@flokaiser
  • Byte
  • 48 replies
  • September 18, 2023
Thank you very much!
Nikos.Kyrm
Byte
Forum|alt.badge.img+13
  • Byte
  • 204 replies
  • November 16, 2023
Hello @flokaiser !
Im not sure If my question is out of thread scope, but I’m looking a way to delete a VM group.
I cant find any option, at least from CommCell.
Best regards,
Nikos
  • Byte
  • 10 replies
  • January 4, 2024
Hello all,
the same for me, can’t find a way to delete a VM Group.
Found only a way to do it by API, but not via browser Delete the VM Group | REST API Docs (commvault.com)
Please help!
Best Regards
Sergej
  • Byte
  • 10 replies
  • January 12, 2024
seems in the version 11.34 (2024) it’s possible to delete a VM group
Best Regards
Sergej
  • May 31, 2024
@Nikos.Kyrm @Sergej sorry for late response as I am just seeing your question. I hope you found the answer. You’d have to select Retire in the Actions menu and once retired, the option to delete will show up in the same menu. Hope that helps
Cookie policy
Cookie settings
