Running only one SQL DB backup
  • March 2, 2022
  • 11 replies
  • 1130 views
Hi Team,
Hope all are doing good !
we have many SQL servers which has 500 DB’s each, is it some option in commvault to run on-demand backup for  only one DB out of 500 DB’s. I knew we have SQL plug-in which can be used from the SQL studio but i am looking for some option from the commvault end,
i found below link to run from commvault end but it is not working as expected, not sure what i am missing here.
https://documentation.commvault.com/commvault/v11_sp20/article?p=18360.htm
Best answer by Scott Reynolds
@Allan0105
From the Command Center you can run a backup of an individual database.
https://documentation.commvault.com/11.24/essential/87377_sql_configuration.html
If you are looking for an option to run from command line you can leverage the ondemand option
https://documentation.commvault.com/11.24/expert/18341_configuring_sql_server_agent_using_command_line_interface.html#specifying-databases-for-on-demand-backup
This command requires you edit a text file with the database(s) that you want to backup. It can be scheduled to run with task scheduler within windows or similar options.
Also if you have specific databases that need one time backup it might be beneficial to create a subclient just for those DBs.
Sunil
Forum|alt.badge.img+13
  • March 2, 2022
Hi @Allan0105
In Command Center Databases list screen we can run on demand backup of any specific DB.
Which FR you’re at?
Sunil-
  • March 2, 2022
Hi @Allan0105
Which FR you’re at?
Sunil-
Thanks Sunil for your quick response. I can run on demand back using command line but need help on scheduling it on specific time.
@Allan0105
  • March 3, 2022
@Allan0105
Thanks Scott for your help here ! I tried to run the qcommand but it is running backup for all the DB’s even though i gave only one DB on the text file. not sure what i am missing. problem in creating new Subclient for one DB is that after backup completed, we cant remove that DB and add to the default sub-client until we delete the sub-client or add another DB to the sub-client.
Any help will be greatly appreciated.
Sunil
  • March 3, 2022
@Allan0105
@Allan0105
Actually I didn’t mean Command line, for running on demand backup. It’s in the Command Center GUI which is a web interface. You can run on-demand backup for any database from the UI.
But for scheduling you need to make it part of the subclient and create schedule for that.
Sunil-
Adding an image if that helps
  • March 3, 2022
@Allan0105
@Allan0105
Sunil-
Hi Sunil,
Thanks for your response. Scott specified that we can use command line to run an on demand backup and can schedule it so when i tried the command line, backup is getting triggered for all the DBS on the Subclient.
command used and on the db.txt, i have specified couple of Db;s
qoperation execute -af D:\xml\backup_template.xml -clientName bteegvpcstvw001 -instanceName BTEEGVPCSTVW001\COMMVAULT -subclientName default –ondemandinputfile D:\xml\db.txt –backupLevel FULL
@Allan0105
Did you create the ondemand subclient first?
  1. Download the create_ondemand_DBsub_template.xml file and save it on the computer from where the command will be executed.
  2. Execute the following command from the <Software_Installation_Directory>/Base folder after substituting the parameters values.
    qoperation execute –af create_ondemand_DBsub_template.xml –clientName client1 –instanceName client1\instance1 –subclientName subclient1 -dataBackupStoragePolicy/storagePolicyName SPdata -logBackupStoragePolicy/storagePolicyName SPlog -sqlSubclientType DATABASE -onDemandSubClient true
    For information on the parameters used in this command, see Subclient Configuration.
  • March 3, 2022
@Allan0105
Hi Scott,
I want to run backup of only one DB in the default sub-client and default sub-client has some 500 DB’s in it, if i need to create on-demand sub-client  and put the DB in that Subclient then i cant move the db out of on-demand sub-client until i add another db to it or delete the on-demand sub-client.
I can do this on the command center by manually clicking the DB but i need to schedule and automate this process. Do we have any options.
@Allan0105
The ondemand subclient is different. There is no Content tab. Databases are not moved from their existing subclient it will only backup the DBs that are in the text file when running the ondemand backup.
  • March 3, 2022
@Allan0105
No the ondemand subclient is different. There is no Content tab. Databases are not moved from their existing subclient it will only backup the DBs that are in the text file when running the ondemand backup.
AAH ! sorry scoot, i missed that. I tried few time but no luck. i believe i am missing something here. can you please review the command once! Thanks.
D:\Program Files\Commvault\ContentStore\Base>qoperation execute -af D:\xml\create_ondemand_DBsub_template.xml -clientName bteegvpcstvw001 -instanceName BTEEGVPCSTVW001\COMMVAULT -s
ubclientName new -dataBackupStoragePolicy/storagePolicyName systemstate -logBackupStoragePolicy/storagePolicyName systemstate -sqlSubclientType DATABASE -onDemandSubClient true
qoperation: Error 0x301:
Performs CommServe operations
D:\Program Files\Commvault\ContentStore\Base>qoperation execute -af create_ondemand_DBsub_template.xml -clientName bteegvpcstvw001 -instanceName BTEEGVPCSTVW001\COMMVAULT -subclien
tName subclient1 -dataBackupStoragePolicy systemstate -logBackupStoragePolicy systemstate -sqlSubclientType DATABASE -onDemandSubClient true
  • March 7, 2022
@Allan0105
Hey Scott,
this was fixed and working as expected, i just copied pasted the commands directly which made the issue. i typed the command and it worked fine. Thanks for your inputs and suggestions.
