Hi
if for a mistake I schedule 2 different job type (Full and Incremental) for a subclient at the same time which job will start ? Full or Incr or will be a “random” choise of Commvault ?
Regards
Federico
Best answer by Damian Andre
View originalHi
Regards
Federico
View originalWith default job management settings, one of the schedules would run and other would fail. The successful job would depend on how the schedules would be configured.
If the setting “queue conflicting jobs” is set (not the default setting) in control panel → Job Management, then both the jobs would start one after the other.
Hello Zubair
If the setting “queue conflicting jobs” is not set which schedule will start? Full, Incr or random ?
It’s seems a random behaviour
Federico
