SCOM Monitoring
  • May 20, 2021
  • 9 replies
  • 1788 views
Bart
Challenger
According to the docs, https://documentation.commvault.com/commvault/v11/article?p=5430.htm , the following needs to be done in order to send alerts to SCOM:
  1. From the CommCell Console ribbon, click the Home tab, and then click Control Panel.
  2. Click SCOM.
  3. In the SCOM Configuration dialog box, type the fully qualified host name of the SCOM Server.
  4. Type the credentials required to connect to the SCOM Server and click Apply.
    Note: The credentials must be for a user who has administrator rights to the SCOM Server
The problem is: Our scom administrator don’t want to give admin permissions to an external tool which they don’t manage. (neither do I).
Is there a way to implement the scom monitoring without that part? (the management pack can be loaded on the scom of course)
Best answer by Bart
@Srikanth We managed to do it ourselves. [since 5 minutes ago]
We managed to retrieve the management pack, and loaded that into scom (after modifying the paths), and alerts are being sent to scom now.
Hi @Bart
Thank you for the question.
When I review case history, there are many cases that quote the same requirements, but that might be just re-quoting the documented requirements.
I will follow up internally and see if we can assign more specific user permissions to enable SCOM alerts.
Stuart
Bart
Challenger
  • Challenger
  • May 20, 2021
Most scom integrations just require the scom administrators to load the management pack on the scom management server. I don’t see any reason why an external tool (commvault) should load the management pack.
  • May 25, 2021
@Bart The management pack is imported when the SCOM server is added to the CS. The agent needs to be installed on the CS as well . Could you please provide more details on which type of user is being used to configure SCOM ?
Bart
Challenger
  • Challenger
  • May 26, 2021
@Srikanth it’s not a question of which user we used for the scom, that is not our question.
commvault requires a SCOM ADMINISTRATOR account in order to install the management pack on the SCOM server. That’s just a BAD PRACTICE and a major security issue.
We don’t want to give administrator access to an external product, because that is just NOT needed. Every other application which has scom monitoring, delivers the management pack so that a scom administrator can upload the management pack manually.
Bart
Challenger
  • Challenger
  • May 31, 2021
@Srikanth any update?
  • June 9, 2021
HI ,
Currently we do need the administrator account in order to configure the management pack. I will check with the corresponding team internally on this and update you by 24/6/21.
Srikanth
Bart
Challenger
  • Challenger
  • June 9, 2021
  • February 28, 2022
@Bart  Would it be possible to share the management pack ready for modification before import?
We are trying to setup SCOM monitoring for Commvault.
I’ve got the SCOM management host name and credentials with proper administrator role on SCOM server.
  1. Control Panel>Scom> i have added above details but when click on Apply, it appears to be not connecting.
  2. We also verified port 5723, 5724 between Commserve and SCOM server, its allowed
Kindly help on this.
