Hi @BartÂ
Thank you for the question.
When I review case history, there are many cases that quote the same requirements, but that might be just re-quoting the documented requirements.
I will follow up internally and see if we can assign more specific user permissions to enable SCOM alerts.
Stuart
Most scom integrations just require the scom administrators to load the management pack on the scom management server. I don’t see any reason why an external tool (commvault) should load the management pack.
@Bart The management pack is imported when the SCOM server is added to the CS. The agent needs to be installed on the CS as well . Could you please provide more details on which type of user is being used to configure SCOM ?
Â
Â
@Srikanth it’s not a question of which user we used for the scom, that is not our question.
commvault requires a SCOM ADMINISTRATOR account in order to install the management pack on the SCOM server. That’s just a BAD PRACTICE and a major security issue.
We don’t want to give administrator access to an external product, because that is just NOT needed. Every other application which has scom monitoring, delivers the management pack so that a scom administrator can upload the management pack manually.
Â
HI ,
Currently we do need the administrator account in order to configure the management pack. I will check with the corresponding team internally on this and update you by 24/6/21.
SrikanthÂ
@Srikanth We managed to do it ourselves. Âsince 5 minutes ago]
We managed to retrieve the management pack, and loaded that into scom (after modifying the paths), and alerts are being sent to scom now.Â
Â
Â
@Bart Would it be possible to share the management pack ready for modification before import?
