Simcallwrapper with networkgateway
  • Oct 31, 2024 5:07 PM UTC
  • 501 views
Good Day everyone,
we’re operating a remote location with a Windows-Server as a network-Gateway between Clients that have no connectivity to CS and Commserver. (Not the OVA)
We proudly got our first unix SAPHana-Client operating in that remotelocation.
We installed a lot of Windows-Clients so far in that remotelocation, which is why we we’re sure that our way would work with linux as well:
- We installed the Client with the silent_setup which is available in the linux-package
- After that we tried the following SIMcallwrapper:
/opt/commvault/Base/SIMCallWrapper -optype 1000 -cshost commserveFQDN -clienthostname clientFQDN -Connectioninfo gatewayFQDN:8403 -user 'clientregister' -password 'password' -ClientGroup 'group that is configured to use proxy'
however this does not work at all and we’re unfortunately unsure why:
Successfully executed given operation.…
SimCallWrapper failed. Please check SimCallWrapper.log under Simpana Log Files. Error [67109051]
Simcall-Log Files state:
31564 7b4c 10/31 17:48:06 ### Start to read input file [/opt/commvault/Base/PreImageModeFile.xml]
31564 7b4c 10/31 17:48:07 ### Successfully got XML info from [/opt/commvault/Base/PreImageModeFile.xml]
31564 7b4c 10/31 17:48:07 ### Successfully encrypted user password. Updating XML now
31564 7b4c 10/31 17:48:07 ### Successfully updated XML with optional client setup info
31564 7b4c 10/31 17:48:07 ### UpdateFirewallInfo is skipped
31564 7b4c 10/31 17:48:07 ### No name change is needed.
31564 7b4c 10/31 17:48:07 ### Successfully updated firewall info
31564 7b4c 10/31 17:48:07 ### Successfully built XML data
31564 7b4c 10/31 17:48:07 ### Start to register client
31564 7b4c 10/31 17:48:07 ### Reloaded FW related registry and config files
31564 7b4c 10/31 17:48:07 ### Send request with ID [bc4c5bbc-cfa6-14be-218b-893e32af2830] via appMgrSvc
31564 7b4c 10/31 17:52:14 ### XML Response :<?xml version="1.0" encoding="UTF-8" standalone="no" ?><CVInstallManager_ClientSetup><SimError ErrorCode="67109051" ErrorString="Backup infrastructure is currently unavailable. Please try later. If problem persists, contact your administrator." errorLevel="2"/></CVInstallManager_ClientSetup>
31564 7b4c 10/31 17:52:14 ### Completed
31564 7b4c 10/31 17:52:14 ### Start to read input file [/var/log/commvault/Log_Files/AutoRegisterOutput.xml]
31564 7b4c 10/31 17:52:14 ### Successfully got response info from [/var/log/commvault/Log_Files/AutoRegisterOutput.xml]
31564 7b4c 10/31 17:52:14 ### SIM server returned error code [67109051]
31564 7b4c 10/31 17:52:14 ### UpdateFirewallInfo is skipped
31564 7b4c 10/31 17:52:14 ### No name change is needed.
31564 7b4c 10/31 17:52:14 ### Firewall info files are reverted back
31564 7b4c 10/31 17:52:14 ### ActivateClientDetails is not retrieved from server.
31564 7b4c 10/31 17:52:14 ### SimCallWrapper failed. Error [67109051]
I saw that Infrastructure unavailable before but unsure what was the cause back then.
The Proxy is cvpingable.
May there be someone to help us please?
Try open the CVInstallManager log on the CommServe would be my next step here to see if there is more clues.
However, 90% of the issues I see logged in the internal KB here suggest a network connectivity error. Try check cvfwd.log on both the client and the network gateway to spot any comms issues.
Onno van den Berg
Forum|alt.badge.img+24
You miss the clientName flag which is required. I would also recommend using the authorization code options instead of username password.
