Specify Permissions / Roles for restore operations
  • February 18, 2025
  • 206 views
Nikos.Kyrm
Hello Commvault,
To restrict restore operations to Commvault users, I see that there is the “Browse and Restore” Role with following Permissions:
There is a requirement to have separated permissions groups / users for restore:
- VMware VM restore
- o365 Exchange online restore
- OneDrive for business restore
Is this possible?
Please for your feedback,
Nikos
Best answer by Nikos.Kyrm
Hello all,
Just wanted to share that I figured this out.
From Commcell, you can set specific users / groups in client level:
After that, assign the Browse and Restore role and should be OK.
Best regards,
Nikos
Onno van den Berg
Forum|alt.badge.img+24
Yes, I think you can achieve this by leveraging server groups and to have different permission groups with roles attached to them applied to them.
Nikos.Kyrm
  • Community All Star
  • February 21, 2025
Hello ​@Onno van den Berg and thanks for your reply!
Do you think it’s possible to “split” the restore roles/permissions between o365 services?
For example to have:
- A group that can restore only Exchange online mailboxes and
- B group that can restore only OneDrive?
Thank you in advance,
Nikos
Nikos.Kyrm
  • April 16, 2025
Hello all,
Best regards,
Nikos
