SQL System Databsases Restore
  • May 4, 2022
  • 1322 views
I have recently been asked if it is possible to restore SQL System Databases without restoring all User Databases in the same SQL instance?
I thought this could be possible in CV however I cant find any way to do so via Web/Java console, only user Databases are listed when attempting to find master, model and msdb..
Any help or thoughts on this would be great appreciated.
Best answer by Bart
https://documentation.commvault.com/v11/expert/18252_restoring_sql_system_databases.html
  • From the CommCell Browser, click Client Computers > client > SQL Server.
  • Right-click the instance, and then click All Tasks > Browse and Restore.
  • In the Browse and Restore Options dialog box, click Advanced Restore, then click the Advanced Options tab.
  • Select Include System Databases, and then click View Content.
so the trick is to select Advanced restore and then click advanced options
Bart
Challenger
  • Challenger
  • May 4, 2022
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • May 4, 2022
In addition to Bart, if you are restoring from the command center you need to select your differential backup in order to recover system databases
