Since a few months we have the problem that the archiving function does not work anymore. Files that were previously stubbed without any problems are suddenly no longer stubbed. Also files that had a recall are not stubbed again. In the logs it says "Reason: [Skipping as file has recall on data access or open attribute ON]". Files are for example jpg and bak. We are already in contact with the support but they don't get any further.
Stubbing no longer works
+3
Best answer by Amulya
Hi
Could you please check if crowdstrike AV is installed on this server. If yes, please exclude this subclient content path from crowdstrike. In one customer case we noticed crowdstrike AV is setting EA attribute.
