Suse11sp4 operating system crash when backup oracle11g database using BLB option
  • June 30, 2021
  • 123 views
crashdump log:
<6>[5258663.115395] EXT3-fs (dm-22): mounted filesystem with ordered data mode
<6>[5431207.839871] 31828: cvbf_attach_block_device(): Attaching to 253:20
<3>[5431207.839877] 31828: ERROR: cvbf_attach_block_device(): Device 253:20 is already attached
<6>[5431241.625666] kjournald starting.  Commit interval 15 seconds
<6>[5431241.626067] EXT3-fs (dm-22): mounted filesystem with ordered data mode
<3>[5435880.559354] INFO: task CvMountd:11008 blocked for more than 180 seconds.
<3>[5435880.559362] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
<6>[5435880.559370] CvMountd        D ffff88084d8a3c24     0 11008      1 0x00000000
<4>[5435880.559381]  ffff880180d1fd38 0000000000000086 ffff880180d1e010 0000000000013400
<4>[5435880.559394]  0000000000013400 0000000000013400 0000000000013400 ffff880180d1ffd8
<4>[5435880.559405]  ffff880180d1ffd8 0000000000013400 ffff880266776240 ffff88084fc40480
<4>[5435880.559416] Call Trace:
<4>[5435880.559460]  [<ffffffffa0326c16>] start_this_handle+0x2f6/0x3a0 [jbd]
<4>[5435880.559485]  [<ffffffffa0326e9e>] journal_start+0x9e/0xe0 [jbd]
<4>[5435880.559505]  [<ffffffffa0350aa7>] ext3_unlink+0x57/0x230 [ext3]
<4>[5435880.559534]  [<ffffffff81170e52>] vfs_unlink+0xb2/0x120
<4>[5435880.559546]  [<ffffffff81173fe1>] do_unlinkat+0x231/0x240
<4>[5435880.559565]  [<ffffffff8147c3be>] system_call_fastpath+0x22/0x27
<4>[5435880.559592]  [<00007fd76d9216b7>] 0x7fd76d9216b6
<0>[5435880.559598] Kernel panic - not syncing: hung_task: blocked tasks
<4>[5435880.559612] Pid: 172, comm: khungtaskd Tainted: P           EN  3.0.101-108.57-default #1
question:
why does CvMountd to always attached this device?
Best answer by Gowri Shankar
Block level backup is a driver based feature.
Could you if the OS level and the kernel version is listed under system requirements for the service pack in use
For your reference adding the latest SP level
V11 SP24 → https://documentation.commvault.com/11.24/expert/3515_block_level_backup_for_unix_system_requirements_01.html
High level overview of how block level backups work → https://kb.commvault.com/article/DAPR0009
Could you also provide some more environment details like If the database is on a snapshot capable volume or native snapshot (LVM) capable volumes ?
Is this a new configuration ?
Forum|alt.badge.img+13
  • July 1, 2021
@Gowri Shankar
Kernel crashdump
Crash time     : 2021-06-28 03:28 (+0800)
Kernel version : 3.0.101-108.57-default
Host           : xxxxxxxxxx
Dump level     : 31
Dump format    : lzo
use lvm  snapshot .
@xuyandaniel , did you see the post above from @Gowri Shankar ?
Please provide the following so he can advise:
  1. Could you if the OS level and the kernel version is listed under system requirements for the service pack in use?
  2. Could you also provide some more environment details like If the database is on a snapshot capable volume or native snapshot (LVM) capable volumes ?
  3. Is this a new configuration ?
