System State Backups
  • August 18, 2021
  • 16101 views
RHITSec
Novice
Hi Folks,
I am constantly battling the error System State Backup error below on many of my windows hosts:
ERROR CODE [6:64]: System state backup of component [System Protected Files;] failed.
Source: servername, Process: clBackup
What is everyone doing to automate the remediation of this problem on your hosts? I have a moderate sized environment (~1500 hosts) so handholding each one when it pops up is a time consuming and arduous process.
Thanks in advance!
Sean
Best answer by MichaelCapon
I’d suggest checking the usual:
  • VSS Writers State (Ensure System Writer is present also)
  • Disk Space / Configured Shadow Storage Limits
For the above, refer here: https://ma.commvault.com/Article/Details/5460
The Application event Log at the time of the issue may show VSS related events also.
Michael
Aplynx
  • August 18, 2021
Depends on what the cause of the failure is. What is causing the System Protected Files to fail?
MichaelCapon
  • August 23, 2021
Michael
@RHITSec , were the above replies helpful, or are you looking for something that more automated?  The challenge with automating this is that the cause for a given System State failure can and will differ greatly between clients.
  • September 7, 2021
@RHITSec Everytime i have a backup with that error, the only way i find to resolve it is to reboot the backed up machine.
Best regards,
Amaral
  • May 10, 2023
I’m facing the same issue. Many of our windows clients are getting this error and reboot fixes it temporarily but the error occurs again. It would be very helpful if someone can provide a permanent fix for this.
Thanks in advance
Scott Moseman
There’s no permanent fix for System State issues (well, maybe Linux...).
Critical and Non-Critical System State Components for Windows File System
https://documentation.commvault.com/2022e/expert/62528_critical_and_non_critical_system_state_components_for_windows_file_system.html
Excluding System State Components from Windows File System Backups
https://documentation.commvault.com/2022e/expert/18491_excluding_system_state_components_from_windows_file_system_backups.html
If you’re seeing “non-critical” items currently as the issue, you can exclude them.
Scott
