systemd-readahead - Permission denied
  • March 29, 2022
  • 721 views
Every time I boot a Linux MA server running CVLT version 11.26.3 I have some messages like those:
[   83.681139] systemd-readahead[1017]: mmap(/opt/commvault/Base64/cvd) failed: Permission denied
[   83.715006] systemd-readahead[1017]: mmap(/opt/commvault/MediaAgent64/CvMountd) failed: Permission denied
[   83.717208] systemd-readahead[1017]: mmap(/opt/commvault/Base64/CVODS) failed: Permission denied
CentOS Linux release 7.9.2009 (Core)
[root@cvault-ma-02 2022.03.29-15:17:26 ]
[ ~ ] rpm -qa | grep systemd
systemd-libs-219-78.el7_9.5.x86_64
systemd-sysv-219-78.el7_9.5.x86_64
systemd-219-78.el7_9.5.x86_64
[root@cvault-ma-02 2022.03.29-15:27:55 ]
Any hint?
Best answer by Mike Struening
Noting this was answered here:
Does the software still work correctly?
Looks like this could be related to SELinux - is it enabled? You could temporarily disable and see if the error goes away. (more info)
Also - did you enable ransomware protection - I believe that enables and sets SElinux policies but it should work correctly out of the box.
  • March 30, 2022
Mike, Thank you. Yes. SELinux is enabled.
It sounds like a conflict between systemd-readahead component and SELinux.
Is there a command to verify if ransomware protection is enabled other than running ./cvsecurity.py enable_protection again?
