we have hyperscale with encryption enabled and we are having aux copy to tape with below settings
basically each tape should give aroung 40 tb after compression but we are only getting 15 tb , do we need to disabled the encryption .
i can see hardware encryption is enabled in the data path setting for tap e
Best answer by SMD
Hi @Ajai
Apologies for the confusion.
I went trhought the notes now
Notes
If you are performing an auxiliary copy operation to tape and the source copy has software compression enabled, you will not see any benefit from hardware compression.
If deduplication is enabled on the source copy and the copy uses software compression, there will be no saving from hardware compression on an auxiliary copy to tape. This is because the data has already been compressed on the source copy.
Software encryption will eliminate any hardware compression. Do not use software encryption when you enable or expect hardware compression of the data.
Here is no mention about encryption on the source copy must be disbaled but speaks about source copy should not have software compression enabled. We can disable software compression on source copy and monitor the outcome.
Encryption is important for data security. If you wish to disable it , you can. But disabling encryption will not be helping us as this is not deduplication data (Tape does not support deduplication).
We would recomend you to enable hardware compression (if not already enabled) if your tape vendor supports it.
@Ajal Tape copy and Deduplication copy is different. Also if we have software and Hardware compression/encryption selected, system will always prefer hardware.
We can make chnage on teh Tape copy, not on the deduplication copy.
for hardware level compression to work , source copy has to plain and un compress state
