i have check on mi commvault server and i have enable the hardware compression on datapath on storage policy copy of primary global!
But my tape are lto8 and there are written only 10Tb while the spec ar 30Tb
can anyone help me to check?
thanks
thanks
Best answer by Collin Harper
Hello
With hardware based compression, the compression of data occurs after we send it to the tape library\drive. Since the hardware is doing the compression we cannot report the compressed size because its happening after we write the data. We are only able to report on the uncompressed size when hardware compression is being used.
Thank you,
Collin
