Is it possible to configure Universal Command Center when commcells are configured to use RADIUS and external two factor authentication? It appears to me this is not supported.
+3
Sharing case resolution:
Since the Commvault Domain is configured to use Radius for all logins I CANNOT login with a user who doesn’t use MFA.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
