Hi i want to doing  vm validations  with network.
By design, vm validate  works without a valid network.But i need the execute post script after vm deployed to esx .
Is there any way to validate vm with network ?
Unfortunately VM validation is designed to not leverage the network to prevent any kind of collisions with production systems.
If you need to run a script I’d suggest using a custom script as per: https://documentation.commvault.com/2024e/essential/scripts_for_application_validation.html
