VMware VSA Backups not honouring Max Data Readers
  • June 1, 2023
  • 137 views
PedroRocha
Explorer
Hello!
VM group has data readers set to 6. But during a backup it reached a lot more. Does any one ever seen this?
Pedro
Best answer by PedroRocha
Support said that the "Number of Readers in Use" does not refer to data readers, but device streams.
Forum|alt.badge.img+18
  • June 2, 2023
Good morning.  Is this v1 or v2 VSA?  If v2, is that a parent or child job?
PedroRocha
Explorer
  • June 2, 2023
Hi!
its V2, and it's a parent job
I also opened a case with Commvault but the answers so far are not convincing me.
"The Streams tab shows only the "Device Streams" to the Storage Policy; it does not include the "Data Readers" from the VSA subclient."
What about READERS IN USE in the image?
  • June 2, 2023
That is most likely where the difference is being seen, the parent job may be showing all of the streams of the child jobs as v2 jobs are multi-streamed.  Is this a Synthetic Full backup?
PedroRocha
Explorer
  • June 12, 2023
