Web console not available on Passive node during Test failover
  • May 27, 2024
  • 173 views
Forum|alt.badge.img+9
We have CommServe LiveSync setup. During test failover I noticed that Web Console and Command Center is not running on passive node, with error message “This service is currently unavailable”.
Is it expected behavior or not for Test failover?
Best answer by AndresL
Problem solved, .NET core installation repair helped on Passive node.
  • May 27, 2024
Hi @AndresL ,
It might be expected depending in your configuration.
We won’t know without checking logs, but I would assume the WebServer is only installed on the Active CS Node, therefore we can expect this when that Node becomes passive.
If you want the WebConsole and CommandCenter to remain operational during CS Failover, you could configure the WebServer and CommandCenter packages on a dedicated server, then set TPPM for the WebServer communication back to the CSDB
  • May 27, 2024
Hi @AndresL ,
No, we have Identical configuration of Primary and passive nodes, both with web server.
  • May 27, 2024
Thank you @AndresL ,
Which WebServer is configured on the Passive CommandCenter? It may be used to configure the Active Node’s WebServer which should be stopped during Failover.
  • May 28, 2024
