CommServe needs at least 10 minutes to reboot due to D:\Commvault\ContentStore\Base\StopProc.vbs
  • March 29, 2025
  • 234 views
RC23
Apprentice
Commvault 11.32.x is running on a Windows 2019 server.
We noticed that when we need to shutdown or reboot our CommServe in case of Windows Updates for example, the whole process takes at least 10 minutes, more often 15 to 20 minutes… One could understand that it is difficult to afford with such amount of time for each reboots.
The shutdown process stays “ stuck “ for several minutes on the step : “ Shutting down of service: Group Policy client “.
A case has been opened at Microsoft support, investigations pointed out that this huge amount of time needed is due to the execution of Commvault D:\Commvault\ContentStore\Base\StopProc.vbs.
If I am not wrong, this file is supposed to allow current jobs enough time to complete smoothly.
MS support asked if it would be possible to “ disable “ temporarily the execution of this file, in order to test if that solves the issue.
-→ Does somebody else is facing the same Commvault behavior at shutdown ?
-→ Knowing that each time we shutdown/reboot CommServe, we make sure that no jobs are running and the scheduler is disabled, what do you think about disabling the execution of this file ?
Thanks for your thoughts, ideas, point of views...
Best answer by RC23
A short update on that issue:
After discussing with Commvault support and knowing that of course, we reboot Commvault server only during an hourly maintenance Windows that lasts 20 minutes and no jobs are running, we agreed that to make sure that all Commvault services are stopped via Process Manager GUI (GxAdmin.exe), before initiating a shut down or reboot of Windows server is an appropriate way to achieve my goal.
And indeed, it seems to be faster to go that way.
Therefore, we can consider this “ issue “ as solved.
CV_GK
  • March 31, 2025
Hi ​@RC23
Please open a support case for this
RubeckDK
Explorer
  • April 1, 2025
Hi ​@rcalvo …
It is a local computer policy setting…. you can edit this:
 … but I wouldn’t recommend disabling it. Unless you do not care about any DDB process that might be running prior to a reboot.. ;-)
/RubeckDK
This may be happening due to OnDemandService or Deduplication engines processes running on the Commserve. The script itself has the logging capability.
Two lines needs to be changed:
1.
'Set outputfile = objFSO.OpenTextFile( "c:\faststartstop.log", FORWRITING, True )
Remove the comment and provide path for Log_Files folder
Set outputfile = objFSO.OpenTextFile( "c:\Program Files\Commvault\ContentStore\Log FIles \faststartstop.log", FORWRITING, True )
2.
LoggingEnabled = false
LoggingEnabled = true
This should allow pinpointing the processes of concern.
RC23
Apprentice
  • August 27, 2025
Forum|alt.badge.img+13
  • March 3, 2026
Hi Team,
What are the other options in this situation?
Can the script be modified to complete faster?
Can the script be disabled?
