I have enabled two factor authentication for commvault specific group in which both domain user and local user are member of , two factor authentication is not working for domain users , is there anyway to make it work
two factor authentication for domain users
Best answer by Nutan Pawar G
Hi
Two factor authentication will not be honored for domain accounts when SSO is enabled.
If you configured the CommCell to allow domain users to log on using Single Sign On (SSO), then Two-Factor Authentication will not take effect on the domain users. We recommend you disable SSO for the respective domain controller.
