CVE-2023-38545 - Curl 7.69 < 8.4.0 Heap Buffer Overflow
  • 17 November 2023
  • 10 replies
  • 2044 views
We have been notified of a vulnerability in the Commvault Agents in tenable. Is there a date by which this vulnerability can be fixed with a patch?
Path : /opt/commvault/Base64/libcurl.so Installed version : 8.0.1 Fixed version : 8.4.0
Regards
Thomas
Badge +15
Hi @thomas.S
You aren’t affected as per: https://access.redhat.com/security/cve/cve-2023-38545
We also don’t use SOCKS5.
I hope this helps.
Chris ​​
Badge +15
Hello @Chris Hollis
yes, this helped me out. Thanks.
Regards
Thomas
Badge +2
What about for the agent running on Ubuntu 22.04.3? Linux FS agent is version 11.32.28
Userlevel 2
Badge +8
What about windows environment?
Does the latest release (Dec 15 2023)  11.34.x address CVE-2023-38545?  Another words did commvault update the version of the following:
PLUGIN OUTPUT - Path : /opt/commvault/Base64/libcurl.so
Installed version : 7.79.0
Badge +15
@bc1410
A quick search on our documentation site for CVE-2023-38545 shows:
https://documentation.commvault.com/2024/expert/security_vulnerability_and_reporting.html
So it’ll be updated in an upcoming maintenance release for 11.34+
@KurtLO  same applies for 11.32
​​​​​​​Chris
Userlevel 2
Badge +8
Thank YOU!
Badge +12
Hi @Chris Hollis
Would you happen to know when we can expect the Maintenance Release which includes the upgraded cURL component?
Badge +12
Apparently, the cURL component was upgraded to 8.4.0 as part of 11.32.36, but seemingly wasn’t really advertised anywhere.
@Amanda Tesla - if the above is correct, would it be possible to have the CV_2023_11_2 advisory updated to note that the cURL components were upgraded? And can we have a “Give feedback” link on the Security Advisory pages? (please)
Badge +4
@Erase4ndReuseMedia We’ve updated the security advisory notice: https://documentation.commvault.com/securityadvisories/CV_2023_11_2.html.
I told the Dev team about your request for a feedback button on the security advisory site. They will look into adding this feature. We think it’s a good idea. :)  Hope this helps!
Badge +12
Thank you @Amanda Tesla, it’s greatly appreciated!
