MFA issue to JAVA and command center
  • January 11, 2026
  • 47 views
Forum|alt.badge.img+2
Since I upgraded the CS to 11.36.83 I wasn’t able to connect with MFA option to web console and JAVA.
Before the upgrade it works fine and nothing has been changed with the users and groups.
I’m also tried to upgrade to 11.36.87 but still no working, when I’m canceling the MFA option we can login with no problem.
Any ideas?
  • January 12, 2026
Hi ​@shay.itah
Kindly verify below settings and share the log details for further review.
  • Ensure local and Domain accounts are in the correct MFA group.
  • Restart Tomcat and MongoDB services.
  • Log back into Command Center and Disable and re-enable MFA for the user group.
  • If issues persist, check for dependencies with Active Directory or SSO settings.
  • Collect logs from CommServe and web servers and verify the evmgrs and webserver logs.
  • If the issue still persists recommend to log support ticket for further troubleshooting.
    https://kb.commvault.com/article/?id=83425
  • January 13, 2026
Thanks ​@Pradeep , I tried the 3 first option that you advice but still not working.
I’m using with local user to connect to commcell and I also tried with AD user with no result.
I’m also checked the evmgrs.log but no any valid information
the log:
8412  2e04  01/13 11:54:12 ### EvSecurityMgr::validateUser() - Attempt to validate credentials of  User [username], id[81] failed with error [0]
8412  2e04  01/13 11:54:12 ### EvSecurityMgr::validateUserwithDBpassword() - Could not Validate user [id=81]
8412  2e04  01/13 11:54:12 ### EvSecurityMgr::validateUser() - Successfully validated credentials of user [id=81]
8412  2e04  01/13 11:54:12 ### EvSecurityMgr::userLogin() - Socket [0x00000000000010C4]: LOGIN ERROR: Invalid login/password attempt with UserName [username] from [CS], Attempt [1/3]
8412  2e04  01/13 11:54:12 ### ::sendResponse() - FAILED [Invalid username/password. Please use valid credentials to log in.]
8412  2e04  01/13 11:54:12 ### handleLoginOperations() -  Encrypted Login Failed.Browser Session Id [5]
8412  2e00  01/13 11:54:12 ### handleLoginOperations() - Socket [0x00000000000010C4] is not found in the socketRegMap. Rejecting MSG_GET_COMM_CELLS
  • January 14, 2026
I have an update -
If I’m trying to login through the webserver and I’m choosing the option “get pin” the system send the OTP to my email and I gen login successfully.
If I’m using the option “get pin” and put the OTP in the JAVA console I can login successfully.
It looks like something with the authenticator app, I tried the option “reset secret key” and also tried to uninstall and install the app but nothing help.
All that start happening from the 11.36.83 version.
Any solution can help me.
