Adding scratch tapes to a Tape Media Group?
  • February 20, 2022
  • 758 views
Owing to issues with network and Cloud we are having to use Tape Media as 2ary storage (offline).  I would like to have 3 media pools:  Daily, Monthly and Annual. Can someone remind me how to assign scratch media to the new media groups ?  I am trying to separate backup sets based on retention.
Help appreciated.
Best answer by jgeorges
Hey @AlfredMJ
Take a look at the documentation link below, this will work you through ‘moving media between scratch pools’.
Once media is assigned to a scratch pool, the media will return there after its contents age out.
https://documentation.commvault.com/11.25/expert/10237_media_operations_configuration.html#b10241_move_media_from_one_scratch_pool_to_another
Cheers,
Jase
Forum|alt.badge.img+8
  • February 21, 2022
Hey @AlfredMJ
Cheers,
Jase
  • February 22, 2022
Many thanks.  Nuisance warnings in CommCell console now eliminated. Many thanks for the clear response.
