aging old backup because of my storage is full
  • June 8, 2023
  • 19 replies
  • 804 views
can you give me some instruction how it’s aging old backup from the commcell console? my storage is full
SparshGupta
  • June 12, 2023
Hi @gogi100
Kindly make sure you are NOT deleting any jobs manually, as such data would be irrecoverable.
You can make use of “Data Retention Forecast & Compliance” report to get below details -
  • Backup jobs that are on each media or disk volume
  • Backup jobs that either exceed their retention criteria or need to be retained
  • Media that can be recycled and a list of media that cannot be recycled based on the copy retention
  • The amount of disk space that is freed and kept for each storage policy copy
  • An estimated date, including the time zone, on which a job is due to be aged
  • Reasons why data was not aged
https://documentation.commvault.com/2022e/expert/39786_data_retention_forecast_and_compliance_report_overview.html
Sparsh
  • June 12, 2023
when i start  “Data Retention Forecast & Compliance” report. i don’t receive nothing
SparshGupta
  • June 12, 2023
@gogi100 - Hope you selected the relevant options -
https://documentation.commvault.com/2022e/expert/39787_viewing_data_retention_forecast_and_compliance_report.html
Kindly raise a ticket with customer support. They would be able to guide you further.
  • June 12, 2023
yes, i used this path, but nothing
  • June 12, 2023
my storage library is
SparshGupta
  • June 12, 2023
Hi @gogi100
Can you try this as well? Double click the library, to see the mount paths mapped to it. Then, right click → View Contents → Sort in descending order of Size of application.
This will give you an overview of which jobs might be occupying the most space on the library. Depending on that, you can validate further when would those jobs be aged as per retention rules.
Sparsh
  • June 12, 2023
i received next
SparshGupta
  • June 12, 2023
Please try this -
SparshGupta
  • June 12, 2023
Also, when was last data aging run? Is it running via schedule or manually?
  • June 12, 2023
at last ‘Data Retention Forecast & Compliance’ is finished, but i don’t understand what i can do?
SparshGupta
  • June 12, 2023
Hi @gogi100
Let’s say job 101 was supposed to be aged on 10th June, 2023 as per retention settings. However, you still see the job.
The report will display the reason on why the job is not pruned yet. You can take corrective action based on the report, followed by running “Data Aging” job manually.
Kindly raise a ticket with Commvault support team. They will be able to immediately guide you with next steps.
Sparsh
  • June 12, 2023
sorry, how i raise a ticket with Commvault support team?
  • June 12, 2023
i have the Data Retention Forecast and Compliance Report
SparshGupta
  • June 12, 2023
To create a ticket please log into ma.commvault.com and select 'Create a support Incident' https://ma.commvault.com/
or call our hotline https://ma.commvault.com/Support/TelephoneSupport it is open 24x7.
Maintenance Advantage Customer Support Portal
  • June 12, 2023
 last data aging run via schedule
  • June 12, 2023
i tryed manually aging data from console, but nothing
SparshGupta
  • June 12, 2023
@gogi100 - Can you please share ticket number?
  • June 12, 2023
my ticket number is 230612-609
