Do aux copies start after the backup copy time retention time was reached. Or do Aux copies start at the same start as the backup copy but just to a different location? I am aware Selective only does Full and Synchronize does Incremental and Full
Aux Copy Schedule
Best answer by Jos Meijer
The basic issue here seems to be that you have max 70 TB per day with 700 GB/hr auxiliary copy transfer speed. This will take you about 102 hours to complete.
At first glance it seems this is due to either a re-hydration or network performance issue.
- What storage device and disk type are you using on the source location?
- Is the target location disk or tape?
If disk, what storage device and disk type are you using on the target location?
Also what is the reason for not using deduplication on this disk target?
If tape, what tape device and tape type are you using on the target location?
Also how many drives are simultaneously available for the auxiliary copy? - How are the source and target storage device connected?
- Are source and target managed by the same media agent(s) or separate media agent(s).
If separate, what is the network bandwidth available looking at NIC and network capabilities?
