Auxiliary Copy slow performance
  • June 30, 2021
  • 1584 views
Forum|alt.badge.img+2
Hi All
I’m having performance issue with the auxiliary copy. This log capture from media agent. Having low data transfer rate. There is 2 media agent installed in this site, one is working fine, another one got issue.
|*5850951*|*Perf*|592185| =======================================================================================
|*5850951*|*Perf*|592185| Job-ID: 592185            [Pipe-ID: 5850951]            [App-Type: 0]            [Data-Type: 1]
|*5850951*|*Perf*|592185| Stream Source:   xxxxx
|*5850951*|*Perf*|592185| Simpana Network medium:   SDT
|*5850951*|*Perf*|592185| Head duration (Local):  [29,June,21 11:58:57  ~  30,June,21 05:31:55] 17:32:58 (63178)
|*5850951*|*Perf*|592185| Tail duration (Local):  [29,June,21 11:58:57  ~  30,June,21 05:32:31] 17:33:34 (63214)
|*5850951*|*Perf*|592185| ----------------------------------------------------------------------------------------------------------------------------------------
|*5850951*|*Perf*|592185|     Perf-Counter        Time(seconds)              Size
|*5850951*|*Perf*|592185| AuxCopy
|*5850951*|*Perf*|592185|  |_Buffer allocation...............................................................     62750                            [Samples - 130998] [Avg - 0.479015]
|*5850951*|*Perf*|592185|  |_Media Open......................................................................         3                            [Samples - 1] [Avg - 3.000000]
|*5850951*|*Perf*|592185|  |_Chunk Recv......................................................................         -                            [Samples - 2] [Avg - 0.000000]
|*5850951*|*Perf*|592185|  |_Reader..........................................................................        19                7426091508  [6.92 GB] [1310.42 GBPH]
|*5850951*|*Perf*|592185| Reader Pipeline Modules
|*5850951*|*Perf*|592185|  |_CVA Wait to received data from reader...........................................     62829
|*5850951*|*Perf*|592185|  |_CVA Buffer allocation...........................................................         -
|*5850951*|*Perf*|592185|  |_SDT: Receive Data...............................................................        22                7441148736  [6.93 GB]  [Samples - 131109] [Avg - 0.000168] [1134.02 GBPH]
|*5850951*|*Perf*|592185|  |_SDT-Head: Signature module......................................................     55011                7441091064  [6.93 GB]  [Samples - 131107] [Avg - 0.419589] [0.45 GBPH]
|*5850951*|*Perf*|592185|    |_SDT-Head: Signature Compute...................................................        35                7321526131  [6.82 GB] [701.35 GBPH]
|*5850951*|*Perf*|592185|    |_Src-side Dedup................................................................     54974
|*5850951*|*Perf*|592185|      |_Buffer allocation...........................................................     54944
|*5850951*|*Perf*|592185|      |_Passing to next module......................................................         1
|*5850951*|*Perf*|592185|      |_Sig-lookup..................................................................        20
|*5850951*|*Perf*|592185|        |_SIDB-Lookup...............................................................        19                            [Samples - 43174] [Avg - 0.000440]
|*5850951*|*Perf*|592185|          |_SIDB:CL-QueryInsert[dbcbkp93]...........................................        16
|*5850951*|*Perf*|592185|        |_Source Side Dedupe stats..................................................         -
|*5850951*|*Perf*|592185|          |_[Signature Processed]...................................................         -                     43174  [42.16 KB]
|*5850951*|*Perf*|592185|          |_[New Signatures]........................................................         -                     26083  [25.47 KB]
|*5850951*|*Perf*|592185|          |_[Signatures Found in DDB]...............................................         -                     17091  [16.69 KB]
|*5850951*|*Perf*|592185|          |_[Application Data size].................................................         -               46141065304  [42.97 GB]
|*5850951*|*Perf*|592185|          |_[Processed Data size]...................................................         -                7321393043  [6.82 GB]
|*5850951*|*Perf*|592185|          |_[New Data size].........................................................         -                4847865640  [4.51 GB]
|*5850951*|*Perf*|592185|          |_[Dropped Data size (percent[33.78])]....................................         -                2473527403  [2.30 GB]
|*5850951*|*Perf*|592185|          |_[Non-dedupable data size]...............................................         -                 115893045  [110.52 MB]
|*5850951*|*Perf*|592185|  |_SDT-Head: CRC32 update..........................................................         1                4927657832  [4.59 GB]  [Samples - 132576] [Avg - 0.000000]
|*5850951*|*Perf*|592185|  |_SDT-Head: Network transfer......................................................     37018                4927657832  [4.59 GB]  [Samples - 132576] [Avg - 0.279221] [0.45 GBPH]
|*5850951*|*Perf*|592185| Writer Pipeline Modules
|*5850951*|*Perf*|592185|  |_SDT-Tail: Wait to receive data from source......................................     63199                4927715368  [4.59 GB]  [Samples - 132577] [Avg - 0.476697] [0.26 GBPH]
|*5850951*|*Perf*|592185|  |_SDT-Tail: Writer Tasks..........................................................       174                4927657832  [4.59 GB]  [Samples - 132576] [Avg - 0.001312] [94.95 GBPH]
|*5850951*|*Perf*|592185|    |_DSBackup: Update Restart Info.................................................         -
|*5850951*|*Perf*|592185|    |_DSBackup: Media Write.........................................................        53                4916084724  [4.58 GB] [310.99 GBPH]
|*5850951*|*Perf*|592185|      |_SIDB:CommitAndUpdateRecs[xxxx]..........................................         -
|*5850951*|*Perf*|592185|      |_Writer: DM: Physical Write..................................................         3                4918420617  [4.58 GB] [5496.76 GBPH]
Best answer by Ryan Carr
Hi Faiez
I would recommend to follow this link below and use our Performance Analysis tool. It would give you a breakdown of where we see a bottleneck and also provides tips and examples on how best to improve the speeds.
https://documentation.commvault.com/commvault/v11/article?p=109223.htm
Ryan Carr
  • June 30, 2021
Hi Faiez
  • June 30, 2021
thank grey...will look into it
  • July 2, 2021
hi grey...found it grey..is there any reason job id did not generate any log?
Ryan Carr
  • July 2, 2021
If you open up aux copy job history from the admin list. right click your job [592185] and send logs
Have it save locally on your Commserve and then you should see the logs for cvperfloganalyze
