Auxiliary copy VS Dash copy
Nikos.Kyrm
Byte
Forum|alt.badge.img+13
Hello to all!
In case of jobs replication (secondary copy), I see that these 2 options are available: Auxiliary copy & Dash copy.
Whats the pros and cons of each?
Dash copy is for deduplicated data (with Commvault dedup engine) and the Auxiliary copy for the rest “transitional data” / jobs?
Lets share your thoughts.
Nikos
Jos Meijer
Commvault Certified Expert
  • Commvault Certified Expert
  • 638 replies
  • May 11, 2022
Hi @Nikos.Kyrm
Both are an auxiliary copy, but by enabling DASH you can reduce network traffic to send only unique blocks if deduplication has been used.
Quote:
“Deduplication provides an efficient method to transmit and store data by identifying and eliminating duplicate blocks of data during backups. An Auxiliary copy job uses DASH (Deduplication Accelerate Streaming Hash) copy, which is an option for a deduplication-enabled storage policy copy, to send only unique data to that copy. DASH copy uses network bandwidth efficiently and minimizes the use of storage resources.”
Source: Additional Copies of Backup Data (commvault.com)
Nikos.Kyrm
Byte
  • Byte
  • 204 replies
  • May 11, 2022
Jos Meijer wrote:
Hi @Nikos.Kyrm
Hi @Jos Meijer ,  thanks or your reply!
So, in case of Dash copy, you must have a Commvault deduplication database, right?
Can DASH copy works if you have a Disk Storage (with deduplication) as a source, and a Azure Blob storage as destination ?
Best regards,
Nikos
Jos Meijer
  • 638 replies
  • May 11, 2022
@Nikos.Kyrm Correct in case of DASH you need a deduplication database.
As for dash copy to Azure Blob, yes this is supported.
All Azure storage solutions shown here are able to facilitate deduplication and therefor DASH.
Source: Supported Cloud Storage Products (commvault.com)
As long as the target location is part of a storage pool (library + (global) deduplication).
Cookie policy
Cookie settings
