Please, why are we having this kind of issue?
When I tried to recopy it, that's the error message I got.
Hi
The jobs on the copy you show in the screenshot are partially available.
This might be a secondary copy and you are trying to copy to a 3rd, 4th, etc. copy where the source for the next copy doesn’t have the complete job to provide to the next copy.
Please try working back a step to a copy where the jobs are complete and attempting a recopy to that copy.
For example:
Primary → Secondary → Tertiary
If you are trying to copy jobs to the tertiary copy from the secondary copy, but the jobs are incomplete, this will fail.
You will need to recopy the jobs from primary to secondary to ensure the jobs are complete.
Try marking the jobs in the secondary copy for recopy from primary and then see if aux copy to the tertiary copy is successful.
Stuart
This is primary that is showing that error.
the issue is that i cannot find it in the source copy
why did it delete or prune wen it has not been copy.
It says:
If Partially Available jobs on a copy are marked as do not copy, the status of the job will change as Partially Available & Disabled. |
If the jobs are no longer on the source (aged), we won’t be able to copy them.
You would have to run the audit history report (put last 365 days) and then attempt to find which user marked those jobs as ‘do not copy’.
https://documentation.commvault.com/11.24/expert/38015_audit_trail_report.html
Let us know how you go.
Chris
Thank You Chris.
i have run the audit didnt find the cuase why is partially available and disable
do ANY of these jobs show on the Audit Trail report?
Audit shows were disabled by admin.
Now who is the admin?
Someone logged in as admin….is there anyone else other than you who uses that account?
If not, might be worth opening a support case.
I would check if you see any simultaneous activities at the disabling time stamp.
