I write backups to an on-prem SAN. I have a small amount of data on one client that needs to be encrypted to meet a data at rest encryption requirment.
Is there a way to only encrypt data backed up from a singe directory on a Windows client? Or a single drive on that client?
If not, what is the best option for encrypting my data at rest with the least impact on backup times. I do not need to encrypt it in transit, just at rest.
Larry Upton
Hello @Larry Upton
The first issue you may hit with needing to encrypt only one clients worth of data is if you are deduping the data. You cannot have half of a DDB with encryption and the other without as it will either ruin the dedup rate or no be secure at all depending on how you cut it.
