Hi team, can share me what are the recommended ‘additional setting’ value should add into the Media Agents for Backup/Aux/Restore job performance? is there any guide over internet can share me? Thanks in advance :)
Basic Setting for Media Agent
Best answer by Scott Moseman
You might see if your NDMP array supports multiple streams per subclient. If not, your other option could be breaking the data up until more subclients. Either way, more streams will typically can help run those jobs to tape quicker.
https://documentation.commvault.com/11.24/expert/129970_ndmp_agent_feature_support_by_vendor.html
https://documentation.commvault.com/11.24/expert/19631_configuring_multiple_streams_for_backups.html
Scott
