Cloud library advice for Commvault?
  • October 19, 2021
  • 119 views
Henke
Explorer
I’ve looked at the list of destinations for cloud library and didn’t find Azure Gov. Cloud. We currently use Azure but will move to Azure Gov Cloud.
Can I create a Cloud library in Azure Gov by just choose Azure and change the url? Or isn’t Azure Gov Supported as destination?
BR
Henke
Best answer by Prasad Nara
We do support Azure Gov Cloud,. It’s under the same Azure vendor, you just need to change the url to point to gov cloud while creating Azure cloud library.
Let me find out!
It might just be a matter of changing the url (and updating our docs here: https://documentation.commvault.com/11.21/expert/9236_supported_cloud_storage_products.html)
Henke
Explorer
  • October 22, 2021
@Mike Struening where you able to find out if it is supported?
//Henke
Mohit Chordia
Explorer
Is your Azure library immutable or WORM Enabled ?
Is your workload on-prem or on cloud ?
How much deduplication or compression do you get on current azure library ?
I did get some info back.  This is planned for a future date, though I’m digging a bit more into the hows and whens.
  • October 22, 2021
