Cloud Library (S3) - Best Practice
  • January 14, 2024
  • 795 views
Evening folks,
I am after some advise/best practice info if possible (happy to be linked to any documentation!)
What is best practice when using multiple cloud libraries (AWS S3) - is it better to an individual cloud library per S3 bucket (which also means multiple DDBs!!) or is it best to have a single cloud library with multiple mount paths to each S3 bucket within said library (which I believe will leave you with a single DDB?)
Many thanks in advance!
@KevinDodd in the past the best practice from AWS was to use multiple buckets, however AWS improved their S3 offering and nowadays there is no need to create multiple bucket as mount points for a cloud library to get the best possible performance.
Hey @KevinDodd,
What is the reason behind having multiple buckets for your library or multiple libraries?
Is there a requirement to split up the data? different sites etc. ?
Scott H
  • January 15, 2024
Hi Kevin,
Thanks for your question!
What are you trying to achieve with the multiple AWS Cloud Libraries?
With this I will be able to better answer your question and provide my recommendations.
Kind regards,
Scott Henderson
Media Management - Technical Team Lead (APAC)
Onno van den Berg
Forum|alt.badge.img+24
dude
Forum|alt.badge.img+20
  • Community All Star
  • September 10, 2025
Following up on this to see if there are best practices/settings from a Commvault perspective when using S3. Is there a document we can refer to make sure the appropriate settings are set once the library is connected to Commvault?
