cloud library type for scality ring
  • 12 August 2021
  • 120 views
Userlevel 2
Badge +7
i have a question regarding the implementation of a cloud library with Scality Ring.
We can create two type of mount path S3 Compatible Storage or Scality Ring.
Which is required ? (i have some cloud libraries already created in S3 compatible storage instead of scality ring type).
There is a difference between them ?
Kind regards,
Christophe
Best answer by Damian Andre 13 August 2021, 15:06
Hi @christophe,
In most cases you want to pick the vendor specific library type rather than choosing the generic S3 connector. We typically co-develop or partner with storage vendors to use their optimized protocols that work best for their system - so you may find some benefits using the proprietary implementation (less overhead, more performance etc.).
I’m not sure about the benefits of this particular implementation but I’ll ask around.
Userlevel 2
Badge +7
Hi @christophe,
Hi Damian,
our cloud libraries was implement with this type S3 compatible storage. i ask this because we currently have some issues with the backend with job integrity and performance.
Kind regards,
Hi @christophe,
Hi Damian,
Kind regards,
Got it. You should never see integrity issues regardless of the library type! Performance could be for a few reasons. Usually we see slow restore or copy performance due to the increased latency of object storage - but usually mitigated by a larger dedupe object size if needed. Some systems prefer many many streams for best performance.
