Have some alerts that just started showing up in the past couple of days for a particular AWS cloud library
Cloud MountPath(s) without pruner MediaAgent [ {Library[Lib1] MountPath[[store2] s3-backup] DeviceName[Device_94]} ] (yesterday and today. Same time each day)
and
Failure Reason: Failed to check status of parent directory, media agent cannot access the storage. (started on the 19th and occurs roughly at the same time each day) (Additionally this error first occurred when the cloud storage was associated with a different Media Agent. )
The library has two mount paths, and the mount error mostly comes from the 2nd path. Although it once reported the other.
Checked the jobs for the storage policy related to it, and it seems that nothing is missing.
Have looked through the logs and other than the similar alert text, I don’t see what could be causing the alerts.
There are multiple storage policies using the same Media Agent and the same S3 bucket. None of the others are having this problem.
Looking for suggestions on what and where to look for.
