Commvault and Isilon
  • January 16, 2025
  • 75 views
Can anyone advise on best configuration for using Isilon as back end storage for on prem Commvault. Would you use Linux or Windows Media Agents ?
RubeckDK
Novice
Forum|alt.badge.img+9
  • January 16, 2025
Hi…
We have a few of these Isllon clusters (20+ nodes) running… providing SMB shares for Windows MAs in grids…. Works well… very stable. They’re backed by CVLT DDBs ofc and performs well during backups… but restores can be a pain depending on model being used.
As I remember sparse file support isn’t enabled by default, so you have to enable this by using the “isi smb settings share modify --sparse-file=True”  command..
/Rubeck
  • January 16, 2025
thank you for your reply. Are you using 25g ports and if so what type of throughput are you getting for backups. Do you have a mixture of VM and Agent based backups. We have many many SQL servers so the throughput of these is my biggest concern.
  • January 16, 2025
Has anyone got any experience of using Linux Media Agents with Isilon being the target storage ?
