Commvault is now a DD Boost ecosystem partner
Forum|alt.badge.img+8
News from Dell :
https://www.dell.com/en-us/blog/dell-powerprotect-appliances-expands-boost-ecosystem-partnerships/
Do we know when integration will be available in CV?
Jos Meijer
Commvault Certified Expert
  • Commvault Certified Expert
  • 638 replies
  • June 3, 2023
You are looking for this?
https://documentation.commvault.com/2023/essential/158314_configuring_data_domain_boost_storage_library.html
DD Boost integration is nothing new, exists since older data domain solutions.
I expect this is a marketing based news item, unless I am interpreting the functionality incorrectly which they are talking about..
It’s not just marketing….it’s huge…no more CIFS/NFS mounts.
Phase 2 and 3 are coming out soon and it brings even more integration benefits.
  • Byte
  • 52 replies
  • June 5, 2023
Correct, but via BoostFS not direct ddboost.
Nice. Thanks.
According:
Best Practices for Data Domain Boost Access
When using the Data Domain Boost Access library, we recommend to use Commvault deduplication and compression with backups. Keep all of the Commvault data being written in the same format to maximize the space savings provided by the device level deduplication of the Data Domain.
Writing already deduplicated and compressed data to DataDomain? Why? Good practice for all deduplication appliances was to disable CV dedup and compression.
Jos Meijer
  • 638 replies
  • June 5, 2023
Nice. Thanks.
Very interested to see what will be introduced during each phase.
Thanks for the clarification :)
According:
I would personally prefer to allocate data with CV dedup and compression looking at the advantages regarding load and savings.
But for this specific product it would not make sense to me, if you you are using for example, the malware scan and the secured vSphere environment to validate if backups are clean.
Forum|alt.badge.img+5
  • Byte
  • 16 replies
  • June 27, 2023
Hi There,
there is also an article availalbe from DELLEMC now .
Data Domain DDBoostFS Plug-In Application Validation and Best Practices for Commvault Simpana v10, v11.
https://www.dell.com/support/kbdoc/de-de/000206561/data-domain-ddboostfs-plug-in-application-validation-and-best-practices-for-commvault-simpana-v10-v11
a major difference that the commvault document is
Under the Advanced tab, Uncheck the “Enabled software compression on clients” checkbox to disable Commvault compression as a best practice when using with BoostFS.
Best Practices – Commvault Simpana
1. Disable software compression and encryption for better datadeduplication
2. Enable multiple streams for greater throughput
3. Up to 63 streams per BoostFS
Additional settings to check
1. Storage Policy copy properties of Primary Global ->Data paths->Data Path Properties ->Block size should be set to 512kb
@lborek i also share the point that a Commvault DDB should not be utilized
  • 249 replies
  • June 29, 2023
This Dell article is a bit outdated as still mentions Simpana and v10. We are in 2023 not in 2013.
After the 11.32 release the documentation now provides additional info about this new integration, let’s have a look at it!!
https://documentation.commvault.com/2023e/essential/158234_data_domain_boost_storage_library.html
RubeckDK
Byte
  • Byte
  • 68 replies
  • July 20, 2023
dude
Byte
  • Byte
  • 331 replies
  • July 30, 2023
Doc: https://infohub.delltechnologies.com/t/dell-powerprotect-dd-series-appliances-and-commvault-integration/
Page 37 Says to uncheck deduplication.
Doc: https://documentation.commvault.com/2023/essential/159813_best_practices_for_data_domain_boost_access.html
"When using the Data Domain Boost Access library, we recommend to use Commvault deduplication and compression with backups."
Should a non all clients have Commvault Dedup Disabled and leave it for DD to Dedup or should both CV and DD have Dedup data?
Cookie policy
Cookie settings
