Commvault Tape encryption
I need to encrypt the data that is getting Auxed to tapes for a specific Client. How do we do?
Any encryption will add overhead (it’s an extra process that has to run), though how long/how impactful; is subject to a host of factors.
My suggestion is to run a medium/small backup with no encryption, then with CV, and again with hardware and see how long each one takes.
  • 630 replies
  • March 25, 2022
Good morning. Please review these resources:
You can choose software encryption:
https://documentation.commvault.com/11.24/expert/7764_software_encryption.html
Hardware encryption:
https://documentation.commvault.com/11.24/expert/7794_hardware_encryption.html
  • Byte
  • 14 replies
  • March 30, 2022
Do we have any extra license for encryption?
Is Commvault encryption is better or the from Tape Library side
Forum|alt.badge.img+23
@Kavya , it depends.  Having CV handle it means you have it all centrally located.  However, the hardware side might be faster.
Depends on your preference and needs.
  • Byte
  • 14 replies
  • March 30, 2022
Does that mean if we enable encryption from the Commvault, the job take longer time than usual to run?
Cookie policy
Cookie settings
