Hello All,
Prior to 11.30 the Enable WORM Storage Workflow was available to use that set the required Retention/Seal parameters on the Storage Pool and in addition, if applicable to the vendor, enabled a lock on the bucket.
https://documentation.commvault.com/2022e/expert/configuring_worm_storage_mode_on_cloud_storage.html
This is no longer supported and is instead set on the Storage Pool.
Unlike the 11.28 Documentation, I am unable to find information and clarification on if there is a process to configure the bucket lock settings directly from Commvault. It was implied in 11.28, that the workflow would set this.
For GCP Storage “What Does the Workflow do? The workflow enables retention policy on the bucket.”
My questions would therefore be:
- Should/Can Bucket Lock be set by Commvault when setting up the Storage Pool in Commvault or is this to be set manually using the usual guidelines of double the retention?
- The 11.28 Documentation stated (I cannot find the equivalent in 11.32) that GCP was only supported with the lock at the bucket/container level.
- “Vendors who support only bucket/container level retention:
- Google Cloud Storage
- Oracle Cloud Infrastructure Object Storage”
When looking at the GCP Bucket settings in the GCP Console, there is an option to enable object based retention. Is there a specific recommendation by Commvault for this - assume bucket level is still the option to go for?
Finally, is there a recommendation for any setting on buckets on creation in GCP. I have had a look in the latest GCP white paper and couldn’t see anything specific.
The 11.28 documentation around the WORM workflow seemed a lot easier to follow than subsequent versions, though that said - maybe I am just not looking in the right place. 😏
Any advice appreciated, and thanks for your time.
G.
