Creating a Storage Policy Copy with Deduplication vs Creating a Deduplication Enabled Storage Policy Copy
  • May 9, 2021
  • 1196 views
Hi guys,
This might seem stupid but I’m a bit confused by these two documents on the Commvault website that talk about deduplicating policy copies.
If I’m getting the below articles correctly, the difference between;
https://documentation.commvault.com/commvault/v11/article?p=12446.htm
and Creating a Deduplication Enabled Policy Copy
https://documentation.commvault.com/commvault/v11/article?p=14132.htm
is that the former is created using a Storage Pool (dedup engine exists) whilst for the latter the Deduplication location is not an existing dedup engine (storage pool) but just a local folder on the media agent?
If the latter is correct and I want to use it to deduplicate additional independent copies e.g. Weekly Fulls and Monthly Fulls on independent libraries against the Primary Copy data, is there a  downside to it?
Need some assistance on this.
Best answer by Sean Crifasi
@Baba Imani
The difference here is in performing the actions via command line or via GUI. The first link goes through the options of creating a new Storage Pool and DDB or joining a storage policy copy to an existing pool.
Sean Crifasi
  • May 9, 2021
@Baba Imani
  • May 9, 2021
Gotcha! But there is an option when you are creating a policy copy and you haven’t selected a Storage Pool, and you can select Enable Deduplication and can choose path. That’s the option I’m seeking assistance with. Does Commvault create a flat-file in the selected path to perform Deduplication between the primary and additional copy? Is this method common for Deduplication between copies?
  • May 10, 2021
@Sean Crifasi I finally found the exact requirement I was after and that’s Creating a Selective Copy using a Library and have posted a new thread for that. I have posted a question regarding Enabling Deduplication on a selective using a folder that isn’t tied to DDB
