Deleted Jobs in Commvault Console Not Reflected in QNAP Folder
  • Oct 23, 2024 11:47 PM UTC
  • 108 views
Forum|alt.badge.img+5
Hi Commvault Community,
I am writing to inquire about releasing space on a storage unit previously used for backups. Here is the context:
  • The library was configured on a QNAP unit as a network shared folder.
  • A Storage Pool was created for the deduplication database, and a Storage Policy was associated with it.
  • All three elements (library, Storage Pool, and Storage Policy) have been deleted to clean up the shared folder. However, despite considerable time passing, the storage has not been freed up. Manual deletion of the folder contents is also not permitted.
Steps Taken:
  1. Deleted the jobs in the Commvault console, but the shared folder still shows "Size on disk."
  2. Performed data verification and Space Reclamation; however, no storage was released.
  3. Deleted the deduplication database, but the folder information was not cleaned up.
  4. Attempted to manually delete the folder contents, but security permissions prevented this, even with the administrator account.
  5. Deleted the library, Storage Pool, and Storage Policy, intending for Commvault to release the folder. Manual deletion is still not possible.
Currently, Commvault has no information about the folder, and we cannot delete it.
What can be done to delete the folder and free up the storage space?
Hello @Alexis
This one is quite odd as you cannot delete a library or a DDB if there is any valid data left to be pruned. When a library is deleted we will perform what is called a “macro” prune where we are not subtle about our removal of the data and just blow it away.
if you have managed to delete the items in CV that means we think the job is done. I am guessing there is something on the storage holding it or its in the recycling bin somewhere.
I recommend a support ticket to review the config and make sure all is good and they can also provide a work around to get around the CV stopping you from deleting the data.
Kind regards
Albert Williams
Hello @Alexis
Kind regards
Albert Williams
