Dell ECS as a on prem S3 library
  • Aug 10, 2023 12:47 PM UTC
  • 355 views
ApK
Explorer
Forum|alt.badge.img+8
Hello fellow Vaulters.
Are there any out there, that have experience with the Dell ECS storage system used for AuxCopy data as a S3 library on prem? Or do anyone have other on-prem S3 storage systems to recommend?
I am in the process of evaluating a new S3 target storage system to host AuxCopy data.
-Anders
Best answer by Wasim
Hi @ApK ,
I would like you to refer to the below document,
https://documentation.commvault.com/2023e/essential/9237_supported_cloud_storage_s3_compatible_object_storage_vendors.html
  • Aug 16, 2023 10:46 AM UTC
ApK
Explorer
  • Aug 16, 2023 10:50 AM UTC
Hi Wasim.
Thanks for your reply.
I’m more interested in real life experiences, as vendors tend to praise them self and not always deliver what they promise :-)
Regards
-Anders
