Can anyone help that how to disable seal deduplication?
Best answer by Collin Harper
View originalCan anyone help that how to disable seal deduplication?
View originalHello
It would depend on what you are referring to. Are you referring to sealing the DDB in the event of corruption or the DDB sealing periodically.
To prevent the DDB from sealing in case of corruption, select the “pause and recover” option under the DDB Availability Options.
To prevent the DDB from sealing periodically, simply un-check the boxes.
These settings are on the Global DDB Policy Copy > Properties > Deduplication > Settings tab
Thank you,
Collin
You are right for what you have mentioned, but from my end, One duplication has been sealed and I want to unseal it. Is this possible?
Hello
Unfortunately once a DDB is sealed it cannot be un-sealed.
Thank you,
Collin
