Disk storage occupied
  • 21 April 2023
  • 75 views
Badge +1
Hi Team,
As per the snapshot, total data written 1.33 TB  out of 10TB . But free space showing me 46 GB only.The same like showing me other mount points. But when check the physical size it is occupied around 10 TB only. Please help me on this.
Badge +15
If you look at the DDB associated with that mount path, how much does the baseline size show as?
Badge +1
It is around 18.72 TB.
Badge +9
Hello @kumara
Please review the R Drive usage on the MA. There is probably another app using up the space.
Check if VSS is enabled and disable it.
