Drill holes / spares files
  • March 11, 2021
  • 1619 views
does anyone knows how to test if my storagesystem is supporting drill holes?
..Chris
Best answer by Anthony.Hodges
Are you using a NAS, because otherwise it is likely you will not have to worry about sparse?
Recent feature releases state on the Library/Data Path properties if detects that Sparse is supported. Without knowing what NAS or Operating System you are using it is hard to provide specifics, but if you are using Data Paths on Windows Servers then the File System attribute is calledĀ FILE_ATTRIBUTE_SPARSE_FILE. Not all NAS vendors openly state however if they support sparse and some may require you to enable it (like Dell OneFS), but if you want to test it out independently from Commvault then you can experiment with fsutil sparse commands (https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/fsutil-sparse).
Anthony.Hodges
Certified Expert
Forum|alt.badge.img+9
  • Certified Expert
  • March 11, 2021
  • March 11, 2021
thx that helped me
