Drives Tape Library with mount status:"Reservation Stuck"
  • August 29, 2022
  • 1654 views
I am executing a database tape backup with RMAN, the backup fails with RMAN errors and in the tape library the drives with Reservation Stuck status are observed, the status of the drives is "Drive Fully Accessible", which indicates Reservation Stuck ?
RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03009: failure of uncatalog command on ch1 channel at 08/29/2022 16:13:07
ORA-00204: error in reading (block 1, # blocks 1) of control file
ORA-00202: control file: '+DS242600413/backup.ctl.galaxy.1'
ORA-15078: ASM diskgroup was forcibly dismounted
RMAN>
Recovery Manager complete.
ORACLE error from target database:
RMAN>
Please have a look on this page: https://documentation.commvault.com/2022e/expert/10644_tape_libraries_troubleshooting_and_knowledge_base.html
You could try to use the TapeTool utility and also look in the messages log on the server. Also check if you have a utility from the tape library vendor that allows you to run tests to see if you can pin point the root cause.
  • August 30, 2022
Reservation and drive accessibility are two different things. The reservation being stuck refers to SCSI reservations on the drive where drive does not appear to be responding to a release reservation. Drive accessibility merely means the drive path is visible to OS on each MA.
  • August 30, 2022
thanks for answering!! How can I identify what is causing the SCSI reservation stuck problem? The operating system of the MA is SunOS 5.11? How can I check for SCSI reservation conflicts in commvault?
  • September 1, 2022
Onno van den Berg
Forum|alt.badge.img+24
