Hi all, Can anyone help or have you had this problem?
Error occurred in disk media, path... \CV_MAGNETIC\V V Cloud] HTTP error conflict.]. For more help, please call you vendor' support hotline
Hello
Can you advise the type of backup and Commvault version?
I’m looking at some other cases that report this error they mostly have been addressed by the customer and closed off without an answer as to what the issue was.
Can you perform a cloud test tool onto the library:
https://documentation.commvault.com/v11/expert/testing_connectivity_with_cloud_test_tool.html
You can also test a number of the functions with this tool:
https://documentation.commvault.com/v11/expert/performing_functionality_checks.html
Kind regards
Albert Williams
Hi
full backup and differential backup types, version 11.28.true, I have tried reading several other cases closed with no answer
Regards
Radi
Hello
Is the cloud library showing online in Commvault? Can you check cloudactivity.log to see any curl errors show up related to cloud?
Best,
Rajiv Singal
Hi
yes, I checked cloudactivity.log, there are some curl errors showing up,
pcvd] CURL error, CURLcode= 28, Timeout was reached
/cvd] Curl Error: 28
/cvd] retryable error
pEvMgrs] CURL error, CURLcode= 60, SSL peer certificate or SSH remote key was not OK
/EvMgrs] Curl Error: 60, GET https://xxxxxx
/EvMgrs] CURL error, CURLcode= 60, SSL peer certificate or SSH remote key was not OK
/EvMgrs] Curl Error: 60, GET https://xxxxxxx
Regards
Radi
Hello
Name - nCloudServerCertificateNameCheck
Category - MediaAgent
Type - Integer
Value - 0
Best,
Rajiv Singal
I know this is old, but hopefully may help someone if they run into the same error. I confirmed that in the cloud logs i did see 403 errors.
After logging into our buckets using s3 browser with the same credentials as what was in the storage library, i confirmed it was a change in how the info was entered with the service host in the mount paths to the buckets.
We had previously had xxxx.xxx.domain:443 for the service host, which worked fine for years. After our media agents had their software cache updated, this would throw errors. The fix was to remove the port info in the buckets to just show xxx.xxx.domain.
